Standing rigging replacement.
Just got home from my first sail with my 7 year grandson on my 47 year old boat. One of his first observations “Granddad that’s a pretty big pole. Is it going to fall down, cause that would hurt.”
When and why do you change standing rigging. Easy answer “before it can fall down.”
There is sailors knowledge based on observations and experiences that have formed the rules of thumb. 6-10 years for salt water exposed rigging and 15-25 years for fresh water rigging. Rough guides that depend on location of the boats sailing experience, how the boat has been used, and how the boat will be used.
On a new to me boat I want to know the condition by inspection of the rigging and all the connections to the mast and hull. If I’m a day sailor with close proximity to repairs and my mast is easily fixed/taken down that is different than if I am planning an extended cruise isolated from repair resources and skilled help.
Racing and heavy weather sailing tests the strength of the rigging. Replacement of the rigging components is more frequent and based on inspection. Kinks in wire is like chafe on a line. It requires more careful consideration of condition, usage, and inspection for signs of failure.
Proper size and material components for the rig are further consideration. When I refitted my mast and rigging I had the help of a seasoned rigger. He advised that with the size of my mast, the manufacturer was known to have undersized the rigging. Based on my sailing plans he suggested we increase the wire and components one size. I base my decisions on my planned usage and condition of rig more than on a number of years.
The reactive answer to your question is a probable Yes it is time.
The resulting knowledge of “The Rigging” was new in 2021, is peace of mind and will serve a little should you decide to sell at a future date. Also there is a sense of confidence when that thunderstorm approachs that the rigging is new and solid. It should be one less worry about will we weather the storm.
Now those 20 year old sails might be the next issue.
Good luck.
