Hi all - my Beneteau sailboat is 25 years old and has an in-mast furling system. I am replacing the main sail and furling line. But for the life of me I cannot get the furling line out because the screw that holds the line in the mast is stuck tight. It’s just a large regular screw (not Philips head) and trying to turn it with a large screwdriver is not working. I don’t think this screw has been touched in 25 years. Yet there is no apparent rust visible. It just refuses to budge at all. I’ve tried banging it, vice-grips, PB blaster, a heat gun, and nothing works. I even broke the snake neck of my Dremel trying to grind the screw more square so I could try to get it out with a socket or vice grip.
I can drill it out if I have to but I am trying to keep it intact for future use. Yet I don’t see any other option at this point. I guess I could replace it with a bolt from West Marine but idk if they’ll have the right size & length.
Any advice would be appreciated.
