What filler would you use to repair cracks in the wooden floor boards of a dinghy? 2 of my marine plywood floor boards need to be filled.
I've sanded down and removed any loose material around the areas. They are always going to be in water after it rains, as they are in the back of the boat.
So i need suggestions as to what has worked for others with this problem and how they repaired it.
Thank you.
Thank you.
