I realize that this is a very old thread, I’ve looked everywhere else on the net and this is the only reference to this topic I can find (for a bene 343). I’m in the process of buying a bene343 and did the survey today. On thé engine full power test it only got to 2600 rpm. At full power there was no vibration, smoke or any other indication there was any problem, the boat got to 7.5 kts in still water. I measured the prop on haul out and it is 17 inches. According to the surveyor that is probably the original. The original yanmar tacho / engine start / stop panel with key has been replaced by the more modern version without key. My hunch is the tacho is mis calibrated, but given the feedback on this thread would appreciate thoughts on whether this could be a problem and what to look for.
Thanks for any help.
The fact that the surveyor thinks the prop "is probably the original" means nothing. You need to contact a prop shop with the relevant information they will need to tell you if your have the appropriate prop for your engine. They will need to know the diameter, number of blades, and pitch. For the engine, they will need to know the engine HP and transmission gear ratio. They will let you know whatever other info might be needed, but I think that's it. Armed with that info, they can tell you what the prop *should be* and can compare that to what it is.
If the boat is overpropped, that will need to be dealt with. A prop can often be re-pitched. If the prop is correct, then it points to an engine issue. Either way, since you are in the process of buying the boat, this should be a negotiating point with the seller.
And yes, it could be that everything with the prop and engine are fine other than the tach being off.
