What is it?
PaulK
Dec 1, 2009
1,537
Sabre 402 Southport, CT
Doesn't match up with any Ranger cabin trunk profile, however. Perforated toerail is not usual with their designs either.
PaulK
Dec 1, 2009
1,537
Loto looks to have won this one! It's being lifted in its slip to keep the racing bottom clean. Toerail, angles of cabin trunk & cockpit coaming look like a good match. Ports may have varied some during production run & with post production changes.
Aug 10, 2020
611
Catalina, Hunter C25 3559 Rocky Mount
it sits in the back of my cove. It hasn't moved in probably a decade. I never got close enough to pay it much attention until today. it's a sweet looking boat!
RussC
Sep 11, 2015
1,734
Merit 22- Oregon lakes
Merit 22.
Fast (213 phrf). comfortable. solid build. Masthead rig with 600 lb lifting keel. sexy as hell. hard to find anything to complain about on this one. love mine;)
Catalina 34 Casco Bay
Is it my eyes or...It looks like it's sitting on bunk planks that are on a some sort of pontoon. AND.. is the mast captured by the boat shed?
Aug 10, 2020
611
It's on a lift in a dock. The dock roof is cut back to clear the mast.
Jan 13, 2009
394
J Boat 92 78 Sandusky
Yep, Merit 22. Crewed on one once. Wind was 15-20 on the nose. Yikes. Water coming through board trunk, hull flexing, and boat going sideways. We turned back half way up the first leg of the race and reached back to the dock. Boat is fast in light air and flat water. Out sails it's rating in light air and flat water. Not a boat for high wind or steep chop area.
Likes: SailingLoto
I didn't know you could lift a sailboat with a roof over it. The cut out would have to be as wide as the spreaders or nearly so, wouldn't it? Also, if it's on pontoons it would be subject to wave action. How does that work?
Aug 10, 2020
611
the cut out (by eyecrometer) is about 6x8, most of the roof is removed on the front half over the boat.
A lift mounts on 4 arms that swing on the sides of the dock slip. the pontoons or floats are mounted on a frame with bunks that attach to the arms. the arms pivot at both ends. the arms keep it all parallel to water level. Each pontoon has a big air line going to it and a hole in the bottom. on the dock is a blower and a control valve. to lower, open valve, water flows in the hole in the bottom sinking the floats. to raise, open valve and turn blower on (high volume, low pressure) it blows air through the air line into the float displacing the water and raising the lift.
nearly all boats here are on lifts, just not usually sail boats due to the keel though. this merit, being swing keel is an exception. Across the cove is an s2 7.8 on a lift as well. that's the only 2 sailboats I've seen on lifts.
I can get a better pic of a boat off a lift, or the lift out of the water if you want to see it in more detail.
