Shock Cord for 45CC companion way
Oct 30, 2020
5
Hunter 45CC Toronto
I'm wondering whether anyone has replaced these and if so what did you use and where did you get it?
Thanks
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
Can you elaborate on that. Not sure if I KNOW what you are referring too.
Oct 30, 2020
5
Hunter 45CC Toronto
The 45CC uses shock cord to support the companionway board (acrylic washboard). The shock cord acts as a spring to counterbalance the weight of the board which recesses into the cockpit floor. One of mine is broken and both need to be replaced.
Rick
Oct 5, 2004
1,098
Oh wow. Completely different setup than mine. A pic might help get some insight. I just have grooves on the sides of the companionway entrance that two acrylic pieces fit in. I just stow them below the steps. Most curious.
Oct 30, 2020
5
Hunter 45CC Toronto
It's one of the sweeter features of the boat. It just floats when working properly. Push to the bottom to open the companionway and it locks. Release and it pops back up again to close.
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
Thanks
Yes, one of mine broke shortly after buying the boat, just remove it, and replace with new bungee cord, I would suggest replacing both at the same time.
Oct 30, 2020
5
Hunter 45CC Toronto
The bungee that is there look like it has a solid core. I'm trying to source something like that but it sounds like regular bungee might work based on your response.
Dec 13, 2018
13
Hunter 45CC Fleetwood, UK
Nothing special about the cord IMHO, I've done it on mine twice now with cord just from the hardware store. It's a fiddly job and you need to make sure you re-caulk the joints properly to prevent leaks.
In case you don't have it, here's the original Hunter factory install instructions. I understand that some boats had springs instead of the bungee cords, but I've never seen one.
Duncan
5
Hunter 45CC Toronto
Thank you so much for those documents. I hadn't seen them before. I have all the materials except the wool pile weatherstripping which I'm picking up tomorrow. Hopefully it goes back together more easily than it came apart. Wish me luck!
