I recently picked up a 1971 O’Day javelin. Can someone please explain how the self bailing works and what plugs I need? In the cockpit is a drain that drains straight through the bottom of the hull. When the boat is in the water without a plug in the cockpit it fills the cockpit with eater. There is also a drain in the transom that will fill the bulge with water if it is not plugged.
my question is if both of these holes should be plugged or to keep water out? How does the self bailing work if they are plugged?
I wouldappreciate any guidance because I am wondering how I can leave the boat in a slip without it sinking.
Attached are picks of the drains. Thanks in advance.
