I've been most alarmed with the stem fitting on my new 1999 Catalina 320. I have a picture of the stem when I purchased the boat in June that shows no rust stains whatever around the stem fitting. Now I have this.
As it turns out, the original stem fitting on the 320 is a known problem. CD sells a modified / simplified / and more robust fitting. My plan is to replace the fitting as my first major project. I suppose that I could tie off the halyards and replace this with the mast standing. However, being cautious, and curious about other fittings on the mast, I think I will take the mast down. I may even think about replacing all the 20-year old standing rigging.
Now I need to find out how to gain access to the fasteners inside the hull!
I read in the Catalina forums that this particular fitting is prone to crevice corrosion because of the wings welded to the sides. The new fitting is entirely made with steel at the thickness at the toggle bolt. The wings are eliminated and there are no welds.
Does this look alarming? Should I be ending my season early? It looks alarming to me.
