Why, Beneteau, why?
Dr. D
Nov 3, 2018
288
Beneteau Oceanis 35.1 Herrington Harbour North
My instruments needed a software update. Updating the B&G Zeus3 was easy: Just stick a microSD card in it and upload. Not so for the Triton2 as that requires a USB drive be plugged into the back of the unit.
The Triton2 on my boat is at the port helm station with no way to access the back of the unit from the cockpit. Down in the aft cabin, I see in the overhead a small panel close to the helm station.
How is the panel attached to the overhead? With four self-tapping screws into the FRP overhead. After those are removed and screwed back in a few times the threads created in the FRP by the screws will give out, then I will need bigger screws, or some other nonsense.
Why, Beneteau, why? The back of the Triton2 will need to accessed now and then. Why not attach the panel in a way that is meant to be removed and replaced?
BTW, if you go about this, here is a tip from a B&G tech: Get a USB extension cable and plug into the back of the instrument. He said you could leave it inserted to make the next time easier. I didn't want to leave it inserted, but using it helped. The Triton2 is over a cavity with lots of wires, cables, and some of the steering connections. If I had dropped the USB drive in there it would be lost. With the cable, if the end slipped out of my hand, I would have the other end still in my hand.
Nov 21, 2007
673
I thought that the Triton displays could get software updates via the Zeus MFD. I've performed software updates on several components this way. One Triton worked, one seems to be failing (insufficient memory, or something similar). My two triton displays are both inside the helm pedestal, the only way to access them is to remove the Zeus MFD first, and then unscrew the retaining nuts by feel...
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
This what I am doing...... I too have several panels that are attached the same way and feel your pain. So I cut about 30 small blocks of teak and am epoxying them behind the holes as I open panels up. Let them dry, then just drill out a small pilot hole and there you go..... All good!
Good Luck
2005 Beneteau 423
Dr. D
Nov 3, 2018
288
SoSound: I thought that also, but it wasn't happening. I called the B&G support desk twice (got through quickly both times) and exchanged emails. I don't know if it how the boat is networked or what, but the only way to update the Triton2 is by a USB drive.
Greg: Good idea! Next time I need to update the device, or access other voids, I will do the same.
Likes: NYSail
Nov 21, 2007
673
Thanks, maybe I'm just completely confused about what I have on my boat. It wouldn't be the first time.
