H26 bow Hatch port hardware
Apr 10, 2010
159
Hunter 26 Boca Chica, Rep. of Panama
Its been 8 months since I replaced this plexiglass but I didn't get the hardware installed before the lockdown here in Panamá. I wish I had taken a photo.
Can some one send me a photo of the lockdown screw assembly. The length of those threaded screws with the black plastic heads. I need to see the plates covering the holes in the Plexiglas. Is one on each side. I may need to replace what I have so a source for these parts would also be very helpfull.
Instead of a separate message I will include this: Can some one tell me the length from the bow to the mast that the gib sail is cut to fit. The boat is 2 hrs away. An inspection Monday and I could see the sock to my roller furler is shredding. The sun here is very hard on the canvas. I can get someone there at the boat to give me the max girth but getting the length might not be possible.
I need to replace the electrical panel or at least some of the switches. can somebody tell me a source.
I believe everything you are looking for can be found right here at the SBO store. @Dave Groshong can probably get you the Jib's J-value and I believe they have the hatch pins you are looking for.
Apr 10, 2010
159
Thanks... I have been in contact but yet assured that they are a available .. will keep trying with Dave
If this is your boat, the specifications are listed here.
