356 Jib sheet keeps getting caught in the rigging
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
You are not the first one to have that happen on a Hunter 356. Good tips proposed in the attached thread.
Jan 5, 2017
151
Hunter 356 SF Bay / Delta
Chucks idea to put some line in there sounds like a cheap and easy fix. Thanks for the link.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
The newer H-36 rigging is setup different no strut needed and don’t have you problem.
Nick
Jun 1, 2004
8,258
The same exact problem, for another boat model, was discussed this past week. There is a gap between toggle and tang that catches the line..... so eliminate the gap by installing a spacer/washer on the inboard side of the tang to push the toggle jaws inward so the outside is flush.
Likes: Ward H
MarcW
Dec 9, 2019
18
Hunter 356 Lancaster
On our boat, I found that there's enough tension on the shroud line that a few taps with a hammer will push it in and close the gap that catches the jib line. The washer idea is next if it doesn't stay put. Cheers.
