I have my adjustable 12-22 whisker pole mounted vertically on the mast with the car on the in-board end so the track is 10' tall. The car is controled with a continuous line running through cheek blocks at top bottom of the track and through a pair of PXR cleats that allow both to be opened or closed with one hand by pulling the length between away from the mast or around the mast.
As for strength, the J on my C30 is 12' so the spinn pole length is fully closed so the pole is full double wall. If I bread that, I have really screwed up something.
My Asym is very large sized to by 1square-inch less than the max size for a PHRF code 4 rating. (When we had it measured, I found out that I screwed up and it was 1 square-inch too big
I so we took the head ring off and lowered it 1" to avoid the 3-second per mile rating.) At this size, it sails very well at really deep angles rigged like a symmetrical spinnaker rigged with the tack on the pole an poled back.
I sail it this way every hear for the 30 mile Admiralty Inlet leg of the Round Whidbey Race. With out the pole, I cannot sail below 155º to 160º which forces me to gibe into and out of the ATS to starboard and the bad reverse eddies to port. With the pole I can stay in the thin sliver of strong favorable current and out of the ATS. Win-win.
The down side is that you don't want to do this on short buoy races because jibing is rather a fire-drill.
