Backing plates? We don't need no stinking backing plates.
Jun 11, 2004
1,933
Oday 31 Redondo Beach
I decided to check out the very hard to get to backing plate under the foredeck deck/anchor cleat on my O'day 31. That was fine but I was stunned to see how the two forward feet of the bow pulpit were attached. Not even a washer! I'm not sure there is even a nut on the outboard end of the two feet. It's my fault I haven't checked and rebeded earlier but I've had this boat for a long time and it has been generally very tight and dry. Guess I've been lucky.
No questions here, I just thought I'd share.
465
Hunter 2008 H25 Lake Wabamun
Any chance that there are aluminum plates laminated in the fibreglass to which the bolts are attached to? My Hunter has these built in.
Likes: MySong
srimes
Jun 9, 2020
211
Macgregor 26D Brookings
What's the core? Plywood? Plywood can be a backing plate, but there should be a washer at least.
RoyS
Jun 3, 2012
1,742
If some of the nuts prove difficult to remove, use a nut splitter tool to break them. Clearly you need washers, at least.
Jun 11, 2004
1,933
I think it's balsa but could be plywood. But either way it's obvious some of the nuts have been sucked in through the layup into the wood.
Jun 11, 2004
1,933
Thanks.
For a couple of them I am going to have to grind off the tops of the bolts and push them down through the deck.
The hrd part, other than access, is going to be trying to figure out how to get some effective backing on the two outboard nuts that lie right on the edge between the cored and non cored sections of the deck. I guess a one piece backing plate should handle that though.
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
... The hrd part, other than access, is going to be trying to figure out how to get some effective backing on the two outboard nuts that lie right on the edge between the cored and non cored sections of the deck. I guess a one piece backing plate should handle that though.
I would probably sand the surface and lay on about 5 layers of 1708, then re-drill. Then the curves don't matter. Also refill the holes first with thickend epoxy. Finally, don't use fender washers (they bend) use extra thick fender washers (Bolt Depot).
I pulled a winch out of the deck because of the same PO stupid (not manufacture--after market winch). The crime was hidden above the liner.
Oct 29, 2005
2,366
Glad you found out through chance rather than through accident.
Ken Y
capta
Jun 4, 2009
5,098
How would you get a nut splitter on any of those nuts if you can't get them to back off at least beyond the glass?
capta
Jun 4, 2009
5,098
View attachment 184845View attachment 184846
You might want to fill the holes with epoxy and redrill.
RoyS
Jun 3, 2012
1,742
Capta, In answer to your question to me of how to place a nut splitter on nuts that are imbedded in the fiberglass; I have no idea. I actually did not carefully study Richard's photos and see the imbedded nuts. I do, however, remember not being able to remove 35 year old nuts holding a bow cleat in the same inaccessible area of my own boat and instead using a nut splitter successfully there. Just trying to help.
1,933
Thanks. Appreciate the help. I may be able to get a nut splitter on a couple if necessary but I'll have to grind off the tops of a couple of them.
Sep 24, 2018
4,698
Catalina 30 MKIII Chicago
The O'Day 25's are built the same way. Nothing more than a piece of scrap fiberglass backing for the forward cleats. They also used a lot of silicone as a sealer
