Hi all - new member here, having recently purchased a 1989 Catalina tall rig. Still learning the boat and replacing/repairing worn out rigging.
On the starboard side cabin top, next to the sliding hatch cover and forward of the winch, she is rigged with a single clutch to secure the main halyard and a jam cleat for the main sheet. I believe this is the factory configuration. Both the clutch and cleat are mounted on a raised piece of the deck - sort of like a small platform that I think was intended for mounting this type of running rigging.
On the starboard side, there is the same raised platform but currently without any rigging. Two lines run through the bottom of the traveler back, past the raised platform and on to the winch on that side: one is the halyard for the genoa and the other is a second halyard that is currently not being used (I assume it is for a spinnaker). Anyway, I want to install the clutch on the raised platform in order to secure the genoa halyard. This is probably overkill because I could likely get away with just securing the halyard to a cleat on the mast, because the halyard is rarely used (we have roller furling). But I don't think there's anything wrong with a bit of overkill when it comes to securing critical lines.
After all of that exhaustive background, I have a simple question: does anyone know what I can expect to find when I drill mounting holes in that raised platform to install the clutch? Is it made of a solid piece of fiberglass or might there be a wood core? If solid fiberglass, any thoughts on the length of the screws I might use? The clutch is a Spinlock XAS (double clutch).
Thanks for any help or insights that you might provide.
