Do Your Maintenance! (Please)
Aug 12, 2020
53
Lancer 36 Pago Pago
The boat i bought in February had not had basic maintenance done for the entire tenure of the previous owner (10 years) it seems.There were numerous engine repairs (2QM20) and services required, such as new fuel and oil filters, oil change, pulling the aluminum fuel tank, draining sludge, and welding numerous holes; replacing the lift pump, and repairing the oil line to the head. I pulled the head to inspect the valves and cylinders; the cooling passages were completely plugged, with completely deteriorated zincs. The valves were ground and lapped, the head was descaled, and the cylinders lightly honed.
The engine ran like a champ after all that, but i was still missing one zinc that protects the block. When it arrived, as i was installing it into its plug, the threads broke completely away from the head of the plug! The plug was the original bronze plug and had suffered from depletion and had basically corroded in half. After nearly 3 weeks, the replacement, made from stainless steel, arrived and was installed with the zinc in short order. Hurray, I can motor off the dock again! Just goes to show that doing basic services is very important to ensuring the readiness of your vessel.
Jul 5, 2011
754
Oday 28 Madison, CT
Doing proper maintenance is not just for the next owner, it's for the current one. For example it helps prevent finding one's self pushing against a swift current going up a river and losing power or at other maybe even more dangerous times. I learned to do it myself as it is so critical to me I will trust no one else's mistakes, sloppiness, forgetfulness (yes, on the part of the pros sometimes!)
Aug 12, 2020
53
Lancer 36 Pago Pago
A good owner will always care more about their vessel than anyone else; I do all my own work also. I did have to teach myself to weld aluminum, the other stuff i did as part of my working life.
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
A lot of problems also come from those who pay professionals for a service that aren't provided, this was the case on my boat. Educate yourself enough to identify where parts/service items are located.
Likes: S/V Honu
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
Completing regular maintenance provides safety and security knowing the boat is ready, identifying any problems while performing inspections makes repairs less expensive. Simple things like checking oil and coolant prior to starting the engine could save you from a really bad experience.
Likes: S/V Honu
Apr 10, 2023
73
Hunter 37c Port of Madison
Do you happen to still have the part numbers for those zincs or remember where you purchased them from? I'm having a hard time describing it in search.
Jul 7, 2004
8,501
Hunter 30T Cheney, KS
I like to do all possible maintenance to create a baseline for future items. I think I have posted most of the surprises I have found since I bought Bella.
I'd like to drain my diesel tank and get whatever gunk may be in there. I've always used a biocide and fuel treatment. We haven't been able to sail for 2 seasons now because of our drought ! :(
WayneH
Tartan 37 287 Pensacola, FL
After 2 years on the hard due to Hurricane Sally, I finally got around to replacing the fuel level sender in my tank. While I had the old unit out, I took a piece of sacrificial clear tubing and a old metal coat hanger and sampled the bottom of my tank via siphon. I was actually surprised that there was no second phase in the sample. :D
Likes: Justin_NSA
Sep 24, 2018
4,012
Catalina 30 MKIII Chicago
There was an article about a guy that drove a million miles with his old Volvo. He preached about following the factory maintenance schedule. Nobody knows more about the inner workings of a mechanical device than the engineers that designed it. Long term testing in the field may reveal shortcomings that simply can't be found in short term lab testing however
