Sudden electrical dysfunction
henris
Oct 12, 2012
12
As yesterday it has been rather windy, I had to use repetitively the bow thruster. When I arrived, my 4 service batteries did not supply their DC, Apparently the Xantrex Link2000 resetted constantly the connections (all of them) if I put AC in the charger the 12v will work but only on the charger. On battery mode alone, Xantrex will loop the reset constantly. I would like to cross from Spain to the Canaries (6 days sailing) but am afraid to do so if the problem isn't solved. My bench is 4 times 600 A/H and has a charge of close to 13Volts.
henris
Oct 12, 2012
12
Hello,
Batteries are Victron AGM 165 A/h a bench of four as service Battery. age 2x 24 month and 2x9 month for the nieuwer pair.
DArcy
Feb 11, 2017
1,786
Islander Freeport 36 Ottawa
I'm not sure what you mean by "batteries did not supply their DC", since you are reading a charge of close to 13 volts. 13 volts is a full charge if your charger is not running. If you are not getting DC, perhaps you have an open breaker or fuse.
