How do you store
Oct 24, 2010
2,405
Hunter 30 Everett, WA
On my boat I have an oil extractor, hoses, funnel with hose, and I keep them in plastic bags in the aft lazarette. They are always oily and nasty. where do you store yours? Have you found an elegant solution?
Ken
Ken
They stay in nasty plastic bags in my basement instead of on the boat. I only use that kind of stuff once a year for oil changes, so at least it doesn’t take up boat space. My bags are in an old cardboard box, but a plastic Tupperware style container would probably be better to keep the oil contained.
Mine also stay home. However, when it is time to travel extensively (post covid) we will carry the extractor and a funnel. Wipe both clean with an oil absorbent pad and probably store in a plastic garbage bag.
Johnb
Hunter 37-cutter Richmond CA
After last use cleaning in a one gallon plastic milk jug with the top cut off. Extractor, tubes and funnels all fit.
Last used empty one gallon oil container gets saved for next oil change. Oil filter goes into a biscotti container with a screw on lid, it has enough space to take used paper towels and disposable gloves as well.
Something different happened on the last oil change. My 3qm30 has a horizontal oil filter and unscrewing it has always precipitated a mess. Last time I got interrupted just as I completed sucking out the crankcase oil and did not get to the filter for about 30 minutes. When I did it came off with no drips at all. I am going to make this standard practice.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Ditto dlochner............equipment is drained and cleaned then placed into separate plastic bags and stored off the boat.............reason is, the kit is only used once annually.
Likes: ggrizzard
Where did the oil in the filter go? Back into the engine?
Johnb
Must have, where it joined the other small amount that does not get extracted. One way or another, the oil filter had only drips when inverted as opposed to the usual little gush that has to be caught as the filter breaks loose.
Oct 29, 2005
2,366
After use, my oil extractor sits in transom locker securely together with cleaning and other stuff. The extraction tube get coiled and sit vertically and secured. The funnel after cleaning and stuff with tissue papers goes into a plastic container which sits in a shelf just under companionway.
All tuck away neat and tidy.
Ken Y
I have used simple green to clean grease off of my axle ball bearings
It always surprises me how well it works.
Nov 21, 2007
673
Similar to your practice and many others. Wipe down everything, blue paper shop towels get stuffed tightly into any openings. Everything goes into a clear plastic trunk along with a larger fuel fill funnel and a couple of other oil items. Then it goes into the lazarette. @Johnb, I love the idea of stuffing the extractor into the plastic jug!
Oct 6, 2007
1,176
Hunter H30 1982 Chicago IL
The oil extractor and hoses go home to my storage locker because they are used only once a year. To avoid any mess in my trunk, I stuff a little piece of oil absorbent paper towel (the blue ones) into each end of the hoses after draining as much oil out of them as I can. Oil funnel gets wiped down and stored on the boat. Extractor is emptied at Pep Boys on the way home.
Oct 24, 2010
2,405
Thanks all. In our case, I changed oil while out. I could have just added oil, but with 90 hours on it, I elected to change. After I bought oil, I found a gallon with the extractor. Well, I have enough oil now. The engine only takes 2 liters.
WayneH
Tartan 37 287 Pensacola, FL
I put the oil extractor in a garbage bag with the hoses. I put rolled up blue shop towels into the ends of the hoses to catch the used oil. My dock box is tall enough to store the extractor inside it's bag standing up. Which is good news as I would hate to drag it 700 miles back to my house.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
Why change oil while you’re out? (PNW). Going over the prescribed interval isn’t going to hurt anything.
Dec 25, 2000
6,060
Been using the Topsider two gallon tank with vacuum pump for years to extract the oil from our engines. Clean and no mess. Keep the tank and pump in a plastic box that is kept stored at home. Yanmar recommends an oil change every 150 hours for our 4JH2-TE and the Onan Genset. Seldom ever reach over 100 hours during the season, but change the oil and filter every year regardless.
That was my thought too. If you are close to the oil change time change the oil before leaving or go over the limit by a few hours.
Jan 4, 2006
7,777
Our solution was to stop doing that any more by buying one of these Easy Drain Valves
Really thought my life was about to change ...................... until I read the installation instructions.
I think most marine engines avoid drain plugs to stop people from draining the crankcase oil into the bilge and from there into the environment.
Live in hope, die in despair.
capta
Jun 4, 2009
5,098
What engine do you have? Is it possible there is a drain, usually in the back end of the pan, and you haven't located it. We had our engine for 9 years and never noticed the drain plug.
