Thank you to @Don Lucas for challanging long held "beliefs"
Continuing the research I couldn't find any specific details from Yanmar but did find the following from CAT - Impact of Generator Underloading
While it is for generators, they get into continuous duty diesels, which for most cruisers this would apply (except those fortunate enough to only use the diesel to get into and out of the marina). By the way, the conclusion supports @Don Lucas operating practices, including "blowing it out" now and then.
www.cat.com
Here are some selected quotes:
GENERATOR SET RATED LOADS First, it is important to understand that generator sets are designed to run and, to be specific, they are designed to run with load. This may seem trivial, but loading a generator set properly is essential to availability, healthy engine operation and long engine life. The ideal operation targets of each generator set will depend on the application and rating. Generally speaking, standby- and prime-rated diesel generator sets are designed to operate between 50 and 85 percent of the full nameplate, while continuous-rated diesel generator sets are optimized between 70 and 100 percent load.
Operating a diesel generator set at load levels less than 30 percent of rated output for extended time periods impacts the unit negatively. ....Running at high idle with little or no load reduces the heat in the cylinder, allowing unburned fuel and oil deposits to leak through the exhaust slip joints.
If maintained properly, diesel and gas generator sets can operate at light loads for long periods of time with no harmful effects. After operation at low load levels, each impacted generator set should operate under increased load to raise the cylinder temperature and pressure, which cleans the deposits from the combustion chamber. In addition, if low load operation is expected to occur regularly, a more aggressive maintenance plan will help to ensure that there is no excessive component wear and the chances for unplanned downtime are minimized.
Engine Load Time Limit 0 to 30 percent 1/2 hour
31 to 50 percent 2 hours
51 to 100 percent Continous
Still some interpretation is needed: From the last sentence of the first paragraph above. It appears that continuous rated diesels are "optimized" to operate between 70 and 100 percent load. If we used the "continuous rating" which is what I interpret the % value referring to (I can't imagine operating at 100% of max rated 3600 continuously) then the optimum cruising rpm would be 2100 rpm to 3000 rpm based on a max rpm of 3600 and a continuous rating of 3000.
Using the table instead of the paragraph it would be 1836 to 3000 (interpreting that the % relates to full rated here in the table and is limited by the manufacturer's continuous rating)
Since a sailboats load can vary widely with hull and prop fouling or even dragging a dingly, I would surmise that these numbers apply only to a boat with a clean hull and properly sized prop and no additional load. I say that because I once had a badly fouled prop and hull and could only get to about 2600 rpm max getting from the mooring to the pier and believe me that engine was overloaded! Luckily it was a short distance.
CAT's white paper isn't perfectly clear but its a lot better than Yanmars. So my conclusion is that stay at or above, 1850 RPM (for a 3000 continuous rated diesel), blow it out now and then, and cruise at the rpm that gives you the best compromise between speed and fuel consumption. After I do my RPM vs speed vs fuel consumption test I'll settle in on a number.
The Impact Of Generator Set Underloading | Cat | Caterpillar
While power systems vary in operation, application and load profile depending on the purpose and complexity, all power systems are designed with common goals: providing reliable power and maximizing system efficiency. To achieve these design goals, it is important to understand system operation...
