- Oct 22, 2014
- 23,439
What do you do? You found the perfect boat for you but on inspection the previous owner took all of the running rigging off the boat and left you with out even a manual to try and figure out how much rope/line to buy. Here is some information I have used in rigging my boat.
When boarding an older boat with no manuals and no lines on board to use as a guide, you can always use the boat and sails to fit the lines to your boat. It was what the original designer did using drawings and rules of thumb that are based on typical use.
How big should the line be?
How long should the line be? How much to buy?
If you are going to use the same diameter halyards for all your lines then add up the length of all the lines and buy a roll of line from the rope shop. Buying a 300 or 600 ft roll is way cheaper then buying a measured 72.65' line at the marine store.
Sail SHEETS -
These lengths are measured based on the boat length and the sails to be used. Again feel in your hand is important, as is checking the sizes of any sheaves bending the line or winch equipment gripping the line. Self tailing winches have a size range for line that can be used. It is a goldilocks type problem. Too big and the line does not fit, too small and the line will not hold. You have to find "Just Right" to be happy.
If all this math and measuring makes you gag, having flash backs to high school math and that day the cute girl in the next row over called you a jerk - "We are OVER!" then there is always the Rope Line Calculators like here at SBO.
Running Rigging Calculator.
Buying your precut line here helps keep the lights on and the computers running that provide this forum.
- Inspect the sheaves on the boat. "Sheaves" those round wheel like things that line runs over. They spin to reduce the friction of the line turning a corner. Your line diameter must fit the sheaves. To big and they will bind, not move smoothly. Sheaves serve to smooth the redirection of your line with minimal friction.
- Touch the line, feel the line. If the line does not feel good in your hand you will not enjoy grabbing the line as you begin to work with it.
- Main Halyard - for a Mast Head Rig: lines need to be long enough to go from where they terminate either at the base of the mast or in the cockpit, up to where they go around the sheave and back to the point they attach to the sail plus a couple of feet to easily secure them. You can estimate the length with a tape measure and boat data (check out your boat on Sailboatdata.com). My mast is listed as 42 feet tall. 2 times that number for going up and down the mast would be 84 ft. The boom sits about 3 ft above the bottom of the mast. I terminate my halyards at the mast. If I buy a line 84 ft long, I will have enough line to go from the boom "goose neck" where I attach the halyard to the mainsail, up the mast, down the mast and about 3-4 feet of line left over to tie the halyard off "both ends" when the sail is not on the boat.
- Jib Halyard - This is where that high school math you said you would never have the need to use, comes into play. The Jib on a fractional rig or a mast head rig runs two sides the length of a "right triangle". You need a line that is the equal to the height and the hippopotamus of the triangle...... ("hypotenuse" just a senior moment, channeling my goof ball friend from geometry class). Start the same procedure here as with the main. Tape measure from the cockpit to the mast base (if needed). The length from the mast base to where the sheave is on the mast for the jib halyard - this is the height of the triangle - (The top of the mast for a Mast Head Rig, or to the exit sheave on the front of the mast for a Fractional Rig.). Plus down the length of the Forestay to the bow where the jib is attached - this is the "hypotenuse length". Add a couple of feet to provide ease of tie off. On my boat that length is roughly 87 feet. I will round that off to 90 feet.
- Spinnaker Halyard - Pretty much follows the same pattern as the Jib Halyard using either the Fractional or the Mast Head calculation dependent on where the spinnaker attaches to the mast.
- Topping lifts - Same technique. If the topping lift is used for a spinnaker pole, then it is the vertical length up and down the mast from the tie off cleat to the topping lift turning block. If the topping lift is used to hold the end of the boom up then use the same calculation as used on the jib.
- If you want to avoid all the geometry math, a cheat is to install the main halyard. (That is the easy one just 2 times the length of the mast plus a bit for luck.) Then knowing the length of the main halyard just use it to estimate what you need for the other halyards. Stretch it out to where you are going to need the jib halyard to go and add or subtract a bit from the length to make it fit the new purpose.
Sail SHEETS -
- Jib sheets run from the winch or cleat on the side of your cockpit, to the sail and around the mast to a point at or stern of the mast depending on the size of the sail (a 90% jib uses less line than a 155% Genoa - but there is no reason you can not use the same length for both sails. It just puts a bit more line in the cockpit to address.). Using a length of line or a tape measure you can get a good approximate length. Add to that enough line to run across the cockpit so you can hold onto the line when the boat is heeling and your on the up wind rail. A rule of thumb the length of the boat plus 3-4 feet should be pretty close.
- Spinnaker sheets - Here you go with a lighter weight of line and most often a little small in your hand. You may need more then one set of sheets for the spinnaker as light weight is used when sailing in light air, but a heavier line come in handy when the breeze picks up. The length is most often 2 times the length of the boat.
- Main sheet. - This one is a bit complex as it depends on the specific way your boat is rigged. To measure start at the point the line is secured to the boat in the cockpit. This might be your traveler or a block and cam cleat. Measure to the block. Then with the boom swung out till it touches the shroud on the port side of the boat, measure each loop around the block to the boom and back till you reach the point that the sheet is terminated on the boom block. With the boom fully extended this length can surprise you. Since the main sheet is constantly being adjusted while the line is under tension, you want to have a feel for the line that will enable you to win at the tug of war that happens when sailing in heavy winds. As big as you can based on the size of the sheaves in the sheet blocks.
