Went out solo yesterday! Weather buoy recorded 29kts gusting 37 and very steep 8.2/8.9ft waves at 5.6/5.7sec. I wasn't quite as far out as the buoy so I estimate force 6 instead of 7. It was still wild!
I set up my camera and I was hoping for more feedback, but the thing stopped recording after 2 minutes
I started with the main only, "2nd" reef, which is really in the 3rd reef position. Still did 4.5-5.5 kts upwind. Spilled as much air as I could often letting the luff collapse. Worked pretty well upwind but had to luff some in the gusts. Definitely a heavy load on everything! Mostly held the mainsheet uncleated but it was hard to pull. Tried 1 jibe and got a rope burn for my efforts lol. Was not able to hold a broad reach as it kept rounding up. Was able to run at 6-8.5 kts. Tried to park/heave-to while I put on a hoodie, and it held for a little while but eventually spun on me.
Then I dropped the main and hoisted my heavy-air jib. Was able to close reach at 4 kts. Less heel than with the main, but also less stable. Felt like more pitching. Couldn't tack. Jibe was fine, just had to winch after. Held hove-to under jib alone just fine.
Decided to call it a day after 3 hours so headed to the river for lunch and a swim.
I feel like a need a deeper reef/smaller main for those conditions. I would like to run 2 sails for balance. Maybe go straight to a trisail?
