Alternator issue
Jul 16, 2020
9
Pearson 34-2 Boston
We are having a problem with belt tension and noticed our alternator seems loose. To our surprise there doesn't seem to be a nut on the end of our "swing" bolt. We just loosened the back and the alternator starting to loosen and we could push it up on the swing and tighten it back down without a nut on the front. Seems odd but it does hold so far. Do we need a nut on the front of the "swing" bolt?
We tried fitting a nut on the end and nothing seems to fit.
Beneteau 323 Annapolis MD
first off, you probably mean the "pivot" bolt? at the 9 o'clock position?
May 27, 2004
2,059
I think he means the "nutless" bolt at the 5:00 position. My Yanmar GM20F alternator mount has the head of that bolt on the front side and a longer bolt with a nut on the back side.
But, since we don't know what the engine model is or what a previous owner may have done in the past, it's just a SWAG.
Jul 16, 2020
9
Pearson 34-2 Boston
Sorry,
Engine: Yanmar 3GM30F
The nutless bolt in the 5 o'clock position is the one I am referring to
Jan 4, 2006
7,773
No doubt about it, I've just got way too much time on my hands while kicking something else around on the computer.
Most likely the engine is a Yanmar by its general appearance and a 3GM by the boat size. Please, always state your engine make and model as a Pearson will contain any number of different engine makes over the years.
The question now is "which swing bolt" as that is not a name for the three supports. I'll take a wild guess and say it's the top one under the belt in the OP's picture.
Jan 4, 2006
7,773
You've answered your own question. The alt. casing at that point is 1/2"thick which is threaded and no nut required.
May 24, 2004
7,228
CC 30 South Florida
Ok threaded casing; back to your "belt slipping" problem. Did you get it resolved? If you reach the end of the swing arm and the belt is still slipping, it either has been streched or it is the wrong size. If the belt is tight and it still slips then it is too thin for the alternator load. Perhaps an upgraded alternator or something is failing causing the alternator to tighten up. Are there any engine fluids like fuel or oil sprying on the belt? Perhaps with heat and wear the belt surface has become glassed and slick and lost its rubbery grip. The proper belt tension is attained when you can deflect the belt 1/4 inch with very light thumb pressure.
Jul 16, 2020
9
Pearson 34-2 Boston
Our solution was that after we loosened the bolt, one person lifted the alternator to tighten the belt, and then we tightened the nut. Seems to have worked so far. There is some vibration when we run the motor and we think that the alternator isn't 100% properly aligned, but it is a lot better than it was! We are getting there. How would we adjust the forward and aft alignment of the alternator?
11,771
You can just put a longer bolt through the alternator adjuster ear (should be 5/16" X 18 but may also be M8 depending upon the vintage of the Balmar.) then lock it down with a nut and locking washer. Also be sure the pivot bolt is sized incorrectly for the alternator feet. Those feet are typically a 10mm bore and some Yanmar pivot bolts are 8mm.
Also, keep in mind that your Balmar alternator is likely 100A or more. This will not work on that 1/2" belt if you cycle your batteries deeply. You will want to reduce the output of the alternator using Balmar's "Amp-Manager" (called Amp-Manager on older regulators) or the "Belt Load Manager" feature used on the newer Balmar regulators.
It's pretty hard to help you if you don't provide all the pertinent information up front..
Alternator model #
Regulator model #
Bank size in Ah's
Bank Chemistry - AGM, GEL, Flooded deep cycle, Carbon Foam AGM, TPPL AGM etc. etc..
This article may also help clear up questions about slipping arms. You may also wish to add a Grip-IT Washer...
https://marinehowto.com/marine-alternator-installation-tips-tricks/
Likes: tfox2069
Mar 6, 2008
1,515
Chech if the alternator bracket is cracked or broken if it causes vibration and loose belt
Mar 20, 2016
595
Beneteau 351 WYC Whitby
First wrong belt ,anytime a belt goes around a small pulley (alternator ) it should be a grip notch an X in the belt number eg BX40. It won't slip and will last longer and run cooler
Put a nut and bolt thru the arm just before alternator ,this will give you something to pry against with screw driver to tighten the belt.
Or better yet convert to a serpentine belt drive for about 400.00 and forget about belt dust and slippage and changing belt
Oct 29, 2005
2,366
Belt tension can be adjusted single-handed with this turnbuckle. Use a suitable length ones and expand it between Alternator pulley and crankshaft pulley to tension belt.
Ken Y
7,773
How veeeeeeeeeeeeeery nice indeed. I thought I was keeping my head above water by using a piece of 1-1/4 X 1/4" alum. flat bar to pry in the curved guide. No damage with soft alum.
This is so much simpler and effective.
Jul 16, 2020
9
Pearson 34-2 Boston
Thanks for the suggestions. Going to order a turnbuckle that is the right size for our set-up and check for cracks in the swing arm.
