Adding Stern Perch/Pulpit seats to a 95 Catalina 250 - can it be done?
Jul 7, 2020
8
Hunter 240 Hefner
Hello All - I'm considering buying an older model Catalina 250WB but I really want Stern Pulpit seats. Catalina Direct sells replacements for newer 250's (I think they came standard after 97), does anyone know if these can be added to older Catalina boats?
Jul 7, 2020
8
Hunter 240 Hefner
I think those require Zarcor require som sort of existing rail - there is very little of that on the older 250. The Catalina Direct Pulpit are "free standing" that mount directly to the fiberglass. I just don't know if the hull shape is similar enough.
If you are handy with a jig saw you might find these posts interesting
Likes: Phil
Oct 24, 2010
2,405
Hunter 30 Everett, WA
I'd love them, but we have a split backstay that's just in the wrong place.
Ken
Nov 21, 2007
673
I went to a local lumber supply yard and bought a couple of feet worth of teak lumber and made a pair of seats for our '90 Beneteau First 285. I started with cardboard for a pattern and then moved to plywood, when I thought that it was working OK, then I went to work on the teak.
When I had to deal with straightening/repairing my stern pulpit, I contacted "RailMakers" in Everett. They were terrific. As a part of the new build (only about $100 difference between new vs. repair of old pulpit) I had them add seats in the corners.
Then I went to Lowes and bought a stair tread. $10. A little cutting, stain, epoxy, and varnish and I created two seats on the new pulpit. They are the best seats in the house.
May 19, 2020
85
Hunter 30-2 Quincy
Those look sweet. What sort of bracket did you use to attach the seats to the horizontal parts of the rail?
Nov 21, 2007
673
The teak definitely helps them to look upscale, but they're a bit crude, actually. The attachments to the rail were stainless u-bolts through stainless steel flat stock. Then the line of screw heads that runs diagonally was a stainless steel square tube (pretty small, to try to keep it from being visible) to help support the seat so that it didn't just split along the grain. I'm also afraid that I can't tell you how well they held up, because we moved to a bigger boat a year or two later. They were a nice addition for a boat of that size. Good luck!
Likes: BOSSailor
Boss. Looking at the Sosound seat it appears to be supported be a sling made of SSstock running under the seat attached to the rails with U-bolts.
As an alternative you can weld a cross bar to the Pulpit tube. Add some welded tabs to the tubes. Screws or bolts thru tabs up into your seats and you have a seat with hidden screws that is secured from beneath. If not satisfied you can always thru bolt the seats to the frame and tabs. In this design the seat sits on the rail not inside the space on the rail. If the board is thick enough it will support the seat of most guests.
Likes: SoSound
Nov 21, 2007
673
@jssailem has it right. I couldn't find any pictures of the under side, or work in progress, but I did mark up the original picture that I posted. The long diagonal square tube was bolted to the two corner tabs, which carried most of the weight. I didn't know if we would like the seats or use them, and I have a history of cobbling together cheap prototypes of ideas to test them out before throwing $$$ at it. If I had used Starboard or some other synthetic material, I don't think that I'd have used the diagonal square tube, but I might have used slightly larger tabs at the three rail attachment points.
