New to the forum. Relatively new to boat ownership (about two years). Just bought a boat from an owner that had two gel batteries that were about 12 years old. When surveyed last fall, everything worked fine. During commissioning this spring, the new boatyard reported they were unable to start the engine and the batteries wouldn't take a charge. They recommended I replace the batteries because the engine wasn't starting and "no one uses gel batteries any longer.". The previous owner was perplexed as the gel batteries had never had trouble. I called around about what type of batteries to replace them with and in the process learned that gel batteries are fairly sensitive to charging. Turns out the engine troubles were associated with the fuel line. I am concerned now that the gel batteries were in fact fine and needed either no charge or a trickle charge and if the boatyard had placed a charge on them like a FLA battery the batteries may have been compromised resulting in it not taking a charge.
Any thoughts?
Any thoughts?
