One of the lockers on the port side of my boat's cabin is cracked along its wall (see pictures). The biggest issue with this is that it won't support weight when using it climb in and out of the cabin. My plan is to screw a piece of 3/4" plywood to the back of it to stabilize it, but then can I just fiberglass over that to cover the cracks and then sand down until flush?
I haven't done any fiberglass work before, but it seems like this shouldn't be too terribly difficult. Would I also need to glass over the part of the plywood inside the locker? If so, would it make more sense to fiberglass cover the wood first, and then screw it in place and try to "fuse" the wood with the original wall so that it looks (sort of) nice?
Advice appreciated.
Advice appreciated.
