On Single-handing
Mar 26, 2011
4,010
Corsair F-24 MK I Deale, MD
... Docking in my slip it's a no brainer at all (upwind slip)....
This is a good example of how expereinces vary. Here, the wind is equally likely to come from any dirrection, something you always check as you make your approach. And the tidal current as well. Docking a 2-4 knot cross current can be a real eye opener; you either find a bulkhead or wait until slack tide, which may only last 10 minutes.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
I was not out of available diesel, but not taking the chance of retrieval. I do have a few friends.:cool:
Just wondering why you would even carry spare fuel, you have at least a 50 gal tank which could keep you running for 2 days straight from full, do you venture that far from port? do you rotate the stored diesel with fresh? Is your filler in the same place as ours starboard transom very awkward to access from the boat?
I only ask as we use our boat many times throughout the season and typically only go through about 25 gal in the 6 months the boat is in use.
Would not lines to the winches on either side of the ET suffice as to control the ET position?
What are you using to cover such a large hull opening 2' x 3" opening in the hull would provide some challenging arrangement to stop water intrusion just wondering how you are setup to do this?
Jul 27, 2011
5,203
Bavaria 38E Alamitos Bay
When I lived and sailed in FL I used to tell my buddies that the wind could arrive from any direction, and at just about anytime and at any speed. I recall more than one race on a "triangular course" where I swear we were heading upwind every leg. Not so in Southern California. In summer, the wind is easterly, or viable and light, in the morning, gradually veering to SW, maybe reaching fully W, in the afternoon, increasing from a few knots to 15 kt, then dies off in the early evening and night. Most sail races here start at 1200 or 1300; earlier there is too little wind to bother with. Nearly every day the same. In fact, the same diel pattern pretty much holds all along the North American coast, as well as inland a couple hundred miles. So, an upwind slip is one that you enter heading west or southwest. It changes only infrequently, usually in winter/spring where some south and southeast wind of the morning persists into the afternoon.
19thol
May 2, 2014
111
Hunter 30 St.Petersburg, Fl
It's not very often that I sail with someone that has experience. So in effect I'm always single handing, except for leaving and returning to the slip. I still struggle with this part of any trip. My slip is subject to tidal flow and as was mentioned earlier, wind that could be coming from almost any direction. My slip is very tight, and even with spotters I always manage to hit something (piling) almost everytime. I so want to go out by myself, but really stress over the docking thing.
