An adventure with my mast light
Nov 8, 2010
11,386
Harbormaster threatened everyone to not be out after dark if you don't have ALL working navigation lights.
That blows my mind. Are there sailors that actually don't care about functioning navigation lights? I can't imagine even daysailing without knowing they are in working order.
Likes: dLj
May 24, 2004
7,190
CC 30 South Florida
An update. It failed again...
. In order to get to the deck plug I will have to lower the mast.
You can do what any electrician would and that is to rewire around that plug. Cut an opening if needed, fish the wiring out near the base of the mast and install a new deck plug. Wiring seems to be suffering from age so perhaps a full rewire would be a better long term option.
Jul 5, 2011
754
Oday 28 Madison, CT
On my boat that top light is 360 degrees and labeled the anchor light, used at anchor only. The mid mast light is for motoring and is not a full 360, probably 180-225 etc and is a steaming light for motoring at night. Neither used when under sail only at night when I use running lights, red/green and white aft off the rear pulpit. The anchor and mid-mast steaming are a pain in the ass to keep working. Maybe not the same setup on all sailboats?????
Nov 8, 2010
11,386
No all sailboat are like that, but that is for sure very common.
Oct 4, 2007
81
Oday 28 Great Salt Lake Marina
Sailors out here on the Great Salt Lake have been spreading rumors for years that the high content salt water will eat a power boats outdrive, engine and even the fiberglass! So the only powerboats on the lake are commercial (brineshrimp) and the authorities. So, many old salts aren't worried about getting run over by a power boat in the dark. But when the harbormaster is out on the Rescue One boat and almost hits someone it becomes a theme for the year. I agree with you it makes no sense. But I have witnessed a sailboat slip out of the dark on my port side and scare the s$%t out of me.....
Oct 4, 2007
81
Not to be picky... but I think that is a barrier strip with one pair jumpered. A bus bar is one where all of the circuits ride together, like a bus. A ground bus, for example. Important when you go to order parts, although they are often in the same catalog catagory and are often cross listed.
There is also a CRYING need to elevate the strip off the floor about 3/4-inch with a spacer, to help keep it dry. And coat everything with waterproof grease when you are done. Pretty corroded!
I listened to the CRYING need and bypassed the bus, car, taxi, terminal block. Direct wired with waterproof connections, and tucked and taped it up out of the path of the water. Glad i went looking for it, my bilge pump was wired in there and the connection had fallen off. I would rather be lucky than good any day of the week, and this was one of those "lucky" moments for me!
Nov 8, 2010
11,386
As you probably leave your mast up year-round and rarely if ever drop it, that's a solid plan. For our Canadian friends who drop every year, those strips are a God-send. Not wild about the location and exposure however. Salt water in the bilge?? Who would have thought??
Apr 5, 2009
3,151
Not trying to be a NitPic but sometimes we use incorrect or pedestrian terms instead of the proper name which leads to confusion.
The all-around white light at the masthead is not a "masthead light". That is the anchor light per COLREGs. The light you call the steaming light at mid-mast is the "Masthead light" is required anytime the boat is motor propelled and must cover an unobstructed 235º forward facing arc.
Likes: Hello Below
Oct 4, 2007
81
Here is a picture of what my power panel has:
When I turn on the "Running Lights" the red/green bow and stern white light come on. When I turn on the "Masthead light" the light on the top of the mast comes on. When I turn on the "spreader light" the deck light comes on. When I turn on the "Bow Light" the light on the front of the mast comes on. So should I use the ColReg names and confuse my crew when I need something turned on? Perhaps I should rename the panel to match the ColRegs, but i know them by these names and my crew can read and know which light I am requesting on.
My boat is a 1982, perhaps the new sailboats have the correct terms on the panel?
Oct 4, 2007
81
YOU CAN TAKE IT DOWN?!? lol
i don't think I have saltwater in the bilge, but the marina is right by the smelter for the kennecott copper mines, and with all that crap in the air and the thick salt air EVERYTHING corrodes. Probably corroding my brain.....
Jul 23, 2019
100
Hunter 18.5 Revelstoke
Is there a chunk of loomex (solid house wire) grafted into that? If so I’d rewire that part of the circuit.
Apr 5, 2009
3,151
Just because the wires are in a sheath does not mean that it is NM solid conductor cable. Romex is the most common brand name but even with Romex, you can get stranded conductor although it is also not suitable or marine use because it uses few large diameter strands.
I suspect that the cable in photo in post #19 is this duplex stranded cable.
Oct 4, 2007
81
It's not romex, although it does kinda look like that. About 10 years ago i had the base of the mast fixed as it was corroded and coming apart. I had sail Rite rigging (Kyle) come out and cut the base of the mast, put in a block to bring it back up to the same height for my standing rigging, reinstall a conduit in the mast (mine was ringing like a bell every night we were out on the boat) and rewire with new lights and fixtures. He installed three of these Romex looking wires for the three lights (top of the stick, front of the stick, and deck light) for the three circuits. They are Stranded, one black and one red. And it does say "Marine" on it just like the cable Hayden Watson pointed to. I had it all professionally done and Kyle does amazing work. I haven't seen him in years, rumor is that he is rigging for the America's cup races.
Oct 4, 2007
81
this got me thinking (a dangerous thing) and I asked this question:
So I started to look at newer panels to see if it had changed, and it has! Masthead has been changed to 'Anchor Light", bow light is "Steaming Light" so that one doesn't follow the colregs completely, and the spreader lights are now called "Deck Lights". I guess I will have to update my panel and my brain. Not sure which will be more difficult......
Beneteau 323 Annapolis MD
When you consider alot of older boats did not even come with lighting and lights, we've come a long way. I wonder if your front-of-mast light was not intended to be the "motoring/steaming" light? with the proper arc of light? /// "Bow light" as YOU have it, would be easily confused with the (pulpit?) mounted runnng white light. I would have called it the "foredeck light" to lessen your confusuion. /// Remember, you're not labeling for those who know what they are doing, it is for those who DON'T know.
