Hey guys maybe someone can help me out before I go removing the gearbox. I changed my oil today and after running the engine noticed that I have a leak right under the bell housing. The leak was milky brown which probably means it's mixed with water. Thought it was the engine oil. Checked the oil in the motor and its nice and clean. Checked the oil in the transmission and it is very diluted and milky light brown/beige color. I pumped all of it out, and filled some more oil and will run it and drain it again to try and get rid of the water. My only question is how the water foundits way into the transmission and where could it be leaking from? It seems to be draining out of the hole in between the two bottom bolts that hold the mounting flange onto the motor bellhousing. Any ideas?
