bolt dropped down pedestal
Jun 30, 2019
17
Hunter 33 (Cherubini) Poughkeepsie
Hi Folks, I have a 1980 Cherubini H33 in pretty good condition. I was replacing the wood under the compass when I dropped a
bolt down the pedestal. Its a Yacht Specialties Company pedestal. I can see what I think is the bolt on the floor at the bottom of
the pedestal. Reaching up from underneath (1 finger just fits, a little), I can feel there is a lip on the channel the rudder cables come through, so the bolt won't roll out. Its non-magnetic material. It doesn't seem like a good idea to leave it there, it case it jams the rudder
at an inopportune moment - is that reasonable? Any ideas for how I can get this out. I really don't want to take the pedestal off.
many thanks
Damian
Mar 6, 2008
1,521
Can you reach it with a metal wire coat hanger and see if you can move it over so it drops down from a hole.
Can you make a lasso and put it at the end of a 1/4" wood dowel and pull the string to trap it and pull out.
Jun 30, 2019
17
Thanks Michael and Joe - I've been trying this and will continue, but there is so much obstruction in the body of the pedestal - the rudder cables, gear and fuel cables, instrument wires - that its tough to move anything else in there. I haven't tried the lasso. I was wondering about the wisdom of drilling an inspection hole in the base to get it out?
Nov 30, 2015
1,343
Likes: ggrizzard
Jun 21, 2004
3,222
Beneteau 343 Slidell, LA
That’s what I was thinking, 3/4 to 1” hole should do it. Goes w/o saying, go slow and don’t drill it into anything important, cause you’ll have to disassemble the whole thing! Put a shop vac hose at the hole to suck it out or at least get it in position to grab it with tweezers or small needle nose pliers.
dmax
Jul 29, 2018
1,355
Telstar 28 Buzzards Bay
I dropped a bolt down the pedestal once and took one of those 3 wire-claw grab tools I had laying around and extended it with some pvc tubing and a dowel to push the button, much like the 60" grab tool mentioned above, and was able to grab the bolt and get it out. You could also try putting a blob of butyl on the end of a long dowel - that stuff is very sticky, if you can get the butyl on the bolt you should be able to bring it up.
Jun 30, 2019
17
Thanks for all your replies - I was successful. The secret was to get enough light down the bottom of the pedestal to grab the bolt. I probably could have used any of your good ideas , but I used a 1/4" dowel with a split end that I could use as a passive grabber. Now I gotta get it all back together without dropping anything else!
Nov 30, 2015
1,343
Well Done!!!
Best of luck in your continued maintenance. :cool:
