video: Untitled_720p.mp4
Getting last-year's new motor ready, and it won't run. In some attempts, it will run rough for 5-10s, then die.
* Spark fires, can hear it in the video
* Propane tank is 1/3 full
* Lever in neutral
* No leaks from the hose (can hear the click in the engine when the valve is opened, and the hose has pressure until disconnected.)
* Choke out, throttle on start. When it is about to die, I can increase throttle and get maybe 10 more secs of run time.
* This motor has started fine before, though it needed ~10 moderate pulls before turning over on a single full/fast pull.
* It would sometimes get into a mode where it would only idle (surging a bit) , and die when increasing the throttle
* 13 hours of run time after the carefully respected break-in
I'm thinking there's a problem with the regulator...
* Lever in neutral
