Running wire for masthead light
May 12, 2020
56
Catalina 275 Sport 31 Quincy Bay
Hi there. I have an O’Day 22 and I’ve rewired everything but the masthead light. There’s a break in the existing wire going from the deck to the panel. Does anyone know how to fish a new wire? Is there open space between the deck and the interior ceiling to pass new wires? I have no idea as to the interior construction and if it’s possible to fish a wire thru that space.
Nov 12, 2009
279
J/ 32 NCYC, Western Lake Erie
Is the mast up or down, and are you running a new wire in the mast or in the cabin?
Mar 29, 2011
169
Beneteau 361 Charlotte,Vt
So I know this doesn't answer your question, but may help and save you some money. There is nothing in the colregs that says that any anchor light needs to be at the top of the mast, and in my opinion it's a bad place for any anchor light. It's high above the line of vision. The regs says that it must be an around white light in the forepart of the boat. So get a white solar lantern and hang it from a halyard. I tie a down haul to a solar lantern, use a halyard to pull it 8-10 feet from the deck and tie the down haul to the bow. The lantern will be suspended away from the mast so it doesn't bang. It also lights up the deck for even more visibility.
Rule 30 (Anchored vessels and vessels aground)
(a) A vessel at anchor shall exhibit where it can best be seen:
(i) in the fore part, an all-round white light or one ball;
(ii) at or near the stern and at a lower level that the light prescribed in subparagraph (i), an all-round white light.​
(b) A vessel of less than 50 m in length may exhibit an all-round white light where it can best be seen instead of the lights prescribed in paragraph (a) of this Rule.
(c) A vessel at anchor may, and a vessel of 100 m and more in length shall, also use the available working or equivalent lights to illuminate her decks.
(d) A vessel aground shall exhibit the lights prescribed in paragraph (a) or (b) of this Rule and in addition, where they can best be seen:
(i) two all-round red lights in a vertical line;
(ii) three balls in a vertical line.​
(e) A vessel of less than 7 m in length, when at anchor, not in or near a narrow channel, fairway or anchorage, or where other vessels normally navigate, shall not be required to exhibit the lights or shape prescribed in paragraphs (a) and (b) of this Rule.
(f) A vessel of less than 12 m in length, when aground, shall not be required to exhibit the lights or shapes prescribed in subparagraphs (d)(i) and (ii) of this Rule.
May 12, 2020
56
The mast is currently down. I'm planning on running a new set of wire in both the mast and then another from the deck (right next to the tabernacle) to the switch panel. It's the run from the deck to the panel that I'm not sure about.
May 12, 2020
56
Th
Thanks for the tip mcrow33. In my situation, it's a masthead light that I'm trying to rewire, not an anchor light. I think I need to stick with a more permanent solution given that the light will be used while I'm under power at night.
Jul 7, 2004
8,542
Hunter 30T Cheney, KS
Th
Thanks for the tip mcrow33. In my situation, it's a masthead light that I'm trying to rewire, not an anchor light..... light will be used while I'm under power at night.
You mean 'steaming light' then , not masthead. Masthead is for anchoring. Steaming light is midway up the mast.
