Bottom Paint Sanding
Oct 28, 2019
46
Hunter 38 North Shore of Boston
I'm going to be sanding and applying bottom paint this weekend for the first time and one of the requirements at my yard is dustless sanding equipment. They don't have any specifics listed, just dustless. As such I have two options for dust extraction that I'd like to see if anyone has thoughts on:
Both options will involve me using my dewalt 20v max random orbital sander as its the only sander I have with a dust collection port. I'll use this with an 80 grit abranet pad. I of course will use a respirator with appropriate cartridges, eye protection, and will likely wear a tyvek suit for both sanding and painting.
Option 1: hook the sander up to my 2.5 gallon shop vac that I dont care about and throw away the filter bag when I'm done
Option 2: I'm a project manager at a general contractor and just todaypurchased some new festool ct26 extractors for my finish guys. I could take one of these down to the yard and connect it to my sander, however I'm somewhat apprehensive about filling a brand new dust extractor for my carpenters with blue bottom paint. Does anyone have experience with how bad this will clog up the filters and how easily it'll come out of the extractor?
Thanks in advance for the advice
capta
Jun 4, 2009
5,069
Sorry, I can't answer your question, but it does make me long for the good old days when I'd just take a sander to the hull, no respirator, dust collector, fancy suit or eye protection. That was my first job in a boat yard, sanding, prepping and painting boat bottoms. That metallic taste, especially when I broke for a smoke, is as fresh in my memory as if it was an hour ago. lol
How did I ever make it to 73?
Jan 4, 2006
7,612
The first thing to determine as you prepare to apply bottom paint, is the existing paint hard or ablative.
Hard need sanding. Ablative does not require sanding as it wastes both paint and money.
Oct 28, 2019
46
I am sure they mean sanders with the built in vacuum. Most yards require them.
I guess my real question is whether that typically means I need a legitimate HEPA dust extractor to be "dustless" or if any shop vac is sufficient
Oct 28, 2019
46
Ablative. I was under the impression from reading online that I should hit it with a quick round of 80 grit to knock off anything especially loose. Another question I have is if I can put any ablative on top of my existing? I'll be selecting a bottom paint based on recommendations for my region - New England.
Feb 10, 2004
4,231
Hunter 40.5 Warwick, RI
Ask if your yard has a sanding setup that you can use or rent. If you do use your own vacuum, Rigid makes a fine dust bag for the inside of their shop vacs that is intended for drywall sanding. I would think that would be perfect for bottom paint as well.
Oct 28, 2019
46
My yard actually subs out this work and doesn't have any equipment that they'd use for it. The Rigid dust bag is exactly what I'd be using if I use my shop vac
The only thing to sand on ablative is places where any buildup has occurred or to sand of barnacles.... and maybe smooth out a rough spot. If you need to fair a gouge you should clean that out also before you start fairing.
PaulK
Dec 1, 2009
1,522
Sabre 402 Southport, CT
I use duct tape to attach my shop vac to my DeWalt hand sander. The bayonet-mount of the dustbag on the sander is the same size as the hose, so two or three layers of tape over the butted pieces and it holds for an hour or two. Getting a new filter and throwing out the old one after antifouling is probably a good idea. Messing up new equipment for your business is probably not.
Likes: BarryL
Considering realities I would go with the shop vac. Well, I already have. I used a shop vac with my orbital sander. I worked pretty well. I think your yard will probably want ground covering or maybe even a tent. If anyone is painting while you're sanding expect some complaining.
Jan 4, 2006
7,612
Don't know what service your yard offers but we always start with their pressure washing the boat while it's still in the slings. And this beast could blow a hole through the hull if held close enough.
After the boat is in the stands, go after the areas that were under the straps with heavy 3M Scotch-Brite scouring pads or equivalent, just make sure they're heavy. Use these open pads and not sandpaper as sandpaper clogs with the organic material. Also use loads of water which avoids dust and keeps the pad clean but only if your yard approves. Our effluent is filtered before discharge to the ocean so no worries.
I don't bother scuffing the pressure washed areas unless I can see loose paint. Most ablative bottom paints contain volatile solvents which dissolve the previous ablative and ensure a good bond. If your's is water based, all bets are off.
I always like to leave the boat for a day before painting to ensure most of the water is out of the paint. Maybe this is what avoids loose paint. See that the paint will be much harder the next day.
As far as ablative over ablative goes, no problem assuming they are main stream ablative paints. Hard over ablative is not recommended (no solid base).
capta
Jun 4, 2009
5,069
I'm sorry, but I really disagree with this. A good sanding gets the old ablative paint back to something the new paint can adhere to.Sanding isn't about cleaning off barnacles and grass, the pressure washing should have done that well enough.
Likes: Rich Stidger
My yard rents dustless sanding kits for just the cost of the vacuum bags you use. As far as I can tell they’re just regular shop vac bags, but I haven’t looked too close.
Most paint manufacturers list paint compatibility charts for going between the same and different types of paint. Pettit’s, for example, is at https://www.pettitpaint.com/media/4361/pettit-paint-compatibility-chart-2019.pdf. I follow the manufacturer’s recommendation to light sand between seasonal applications of matching ablative.
Jan 4, 2006
7,612
And well you should. After all, this is a forum and there is little I am willing to accept without some sort of proof.
My first clue comes in part from the West Marine product description:
I see the paint dries, it does not set by cross linking with oxygen (as do most paints) so its solvents are likely able to re-dissolve the paint after it dries. This is the case with this paint. Take some new paint and rub it onto some previous ablative paint. The surface of the old paint stays sticky until it dries. Take an organic solvent like acetone, benzene, or lacquer thinner to old ablative paint and watch it dissolve onto a solvent soaked rag. Does a good job of dissolving the old ablative.
Given that the old paint dissolves nicely in its own solvents, you are going to set up as good a bond as possible under the circumstances, sanded or not.
Bob S
Sep 27, 2007
1,813
Beneteau 393 New Bedford, MA
Jan 4, 2006
7,612
I read years ago on this site about using drywall wet sanding screens with a pole.
Could work as long as you get the dirty parts under the straps and only use the water in the bucket. Don't worry about the rest of the hull.
Check with the manufacturer's website for prep before painting. Ablative paint often needs a quick sanding to remove any loose paint and give some tooth for the new paint.
The best DIY dust collection I have seen and used is a Dust Deputy. I have one and used it when I removed the bottom paint from my boat. Connect a long hose to the Dust Deputy, connect the Dust Deputy to a good shop vac, the small ones aren't strong enough, and 99+% of the dust will be collected. I put a filter bag in the shop vac to collect anything that gets that far. When I did the bottom of my boat I collected 5 gallons of paint dust in the DD and the filter bag in the vac was empty.
I like this idea.... and will probably borrow it the next time I bottom paint. Seems to me that if the goal is to keep toxic dust from flying around the yard, the best way is to not produce any in the first place. The final issue will be... what to do with the bucket of slurry you end up with. You can't just pour it down a drain. I guess you could let the water evaporate over time and then collect the solids and dispose of them properly.
Likes: Justin_NSA
dmax
Jul 29, 2018
1,320
Telstar 28 Buzzards Bay
Check out this article from Practical Sailor on a DIY dustless system - I think it was written by Drew Frye who is on this forum:
