Ditto what jssailem stated, buy Peggy Hall’s book for solutions to your plumbing & odor problem. Even though you have a long run from the head to the holding tank, this may be a contributing factor to your problem; however, I don’t recall there being an odor problem that is specific to Hunter 33’s. Nice boat, i’ve been aboard one many years ago and liked it . After purchasing two boats with odor problems, one from mold because of a closed up unattended boat & one that had a half filled holding tank that sat unattended over the course of a few hot summer months, I can identify with your problem! The problem can be remedied and the odor eliminated over time. If you purchase, get the cushions off the boat immediately. Remove the covers and wash the foam thoroughly in a bath tub or kiddie pool thoroughly & let them dry in the sun, then wash the covers with an upholstery cleaner and reinstall them on the foam and again let the foam / covers dry in the sun for a few days. Keep the cushions off the boat until you fix the source of the boat odor. The hoses are permeated and have to be replaced with high quality hoses, trident or raritan hoses are the standards, raritan sani flex is preferred. If possible, remove the tank and clean it completely with detergent & bleach. This would also be a good time to evaluate the tank vent line and ensure that it is an adequate size diameter. Replace the toilet with a raritan or at least retrofit the toilet to include a raritan pump. With a plumbing system such as found on the 33, I would use fresh water only, to thoroughly rid the hoses of any effluent to prevent the new hoses from quickly becoming permeated. Peggy is the go to source as how to accomplish this. Keep the holding tank pumped out after use & flush it several times with fresh water when you pump out. Now you can address the remaining odor in the boat. Ventilate for days with fans & open hatches. Clean every interior surface, including the bilge and areas under the floorboards, as well as wood surfaces, with a mild bleach & your favorite smelling detergent. I like to wipe the wood surfaces with lemon oil for mold inhibiting action and pleasant aroma. Continue to ventilate, and when the odor is completely gone, bring the cushions back aboard. It’s quite a bit of work and I doubt if you’ll find someone to do a thorough job, so I recommend doing it yourself. Be sure to discount the cost of your labor from the price of the boat, cause it is a nasty job and a lot of work; however, once you get it odor free, you’ll have a great boat!
