Looking at some boats, would like some input
7,521
Alden 50 Sarasota, Florida
All boats sail. Given your intended use, head room below (ability to stand up) might be the most important consideration.
Sep 24, 2018
3,639
Catalina 30 MKIII Chicago
Trying to lift a 95 lb motor on the deck of a 25' boat is a very difficult task without some sort of assistance or mechanical advantage. I found that out when my brand new outboard bracket snapped in half
Jul 27, 2011
5,134
Bavaria 38E Alamitos Bay
Yes, silly. A silly notion. It won’t work out well w/the 15 hp on the sailboat. When you arrive to the trailer launch place, put the engine on the inflatable if you can, and leave there until packing up to go home. Tow the dink.
May 7, 2020
4
TBD TBD TBD
Ya I've seen arches with pullies and stanchion poles used to winch outboard, thought I would ask if anyone has done on this size boat. Kato Marine makes a 130lbs stanchion pole lift. Thanks for the input.
May 7, 2020
4
TBD TBD TBD
Thanks for the insight, guess those 15hp motor brackets don't actually work. Towing it is.
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
I don't know if you got a completely accurate answer offline but just in case they didn't mention it - boats drift. Sometimes almost as far as threads.
