I finished the charging system wiring Monday - came up one ring terminal short. Tuesday, went back and completed everything. Minor glitch with the connection to the battery charger; a just enough lose connection at the charger. Connected the boat to shore power, turned the AC main on, no smoke or flames, checked the cabin outlets - good. This time the charger came right on line.
So, I happily flipped the DC main and started going through the circuits. Everything came on as it should. No problems. Turned everything back off and just let the batteries charge up.
Feeling pretty pleased with myself, I thought it time to take a break and enjoy a beverage. While relaxing, it dawn on me that I had power to the DC side, but I didn't remember turning a battery on. Checking the switch, sure enough it was off. So much for a relaxing break.
When I did the wiring, I wired the positives of each bank one at a time, just so I didn't confuse myself. Going back and checking the connections - one bank at a time - if tab A was suppose to go into slot B, that's what I found.
I'm stumped.
I do have two suspects in my mind:
- The schematic I have for the 2GM20 shows this vague, nebulaes connection from the the back of the alternation that kind of, sort of shows it connecting to the battery switch. Not physically finding this wire, I connected directly from the alternator to bank 1. If there is an existing connection, by connecting to bank 1, did I bypass the switch?
- The battery switch itself. It's 35 yrs old. With all of the detaching and re-attaching of wires and just went tango uniform on me?
However, I could be completely wrong. Attached is a PDF of the system as built.
I'm stumped.
