Adding a spare halyard on h41
Feb 10, 2017
305
Hunter 41 Progreso
Hi to all h41 owners, my h41 only comes with an halyard each for genoa, spy and main, I would like to add another spare one. Do you have a spare one? Did it comes standard or was an add on? If it was add on did you make exterior or interior, please explain. My Selden mást have not an extra hole to add one, should I go with an exterior one?
Best regardss
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
......my h41 only comes with an halyard each for genoa, spy and main, I would like to add another spare one. Do you have a spare one?
My Hunter 386 and 46 came with a halyard each for genoa, spinnaker and main sails and did not come with a spare halyard. Curious what purpose a spare halyard will serve? If it is to climb the mast, use the spinnaker halyard for that with the topping lift as a safety.
Feb 10, 2017
305
Hunter 41 Progreso
.fore, the only halyard to climb all the way up is the topping lift, has the main hylyard is for a roller in mast one.
Feb 21, 2013
4,638
Ditto ice breaker ..............topping lift could be used as a mainsail halyard if that failed.
