Beaching your sailboat
Apr 13, 2020
21
Hunter 20 Canyon Lake
What's the policy on running your boat aground on purpose. Will, it hurt the boat to let it rest on sand? I sail a Macgregor 25 and was thinking about checking out some islands
Feb 20, 2011
8,062
Macs are great for lake beaching, hopefully on sand. The trick may be getting back aboard when pushing off. ;)
Edit- in a number of ways, I miss my Mac.
Apr 5, 2009
3,211
If you are beaching in a tidal region, make sure that then next tide is higher than the tide is when you beach and make sure you set and anchor so that it doesn't wander away. The same goes for dinks. Every year in these parts, someone looses a dingy after the "pulled it way up the beach" only to come back to find the tide has come in and stolen their boat. We can have a 15' vertical tidal range in my harbor.
I beach my Hunter... and have beached a Mac 22 many times. Regarding "damage" on a lake..no... on the ocean it depends on the surf. Surf can beat your boat up
May 25, 2012
4,338
life is choices. i would never ever beach any craft, canoe, motorboat, sailboat, ............ just saying !
i like clean bottoms :)
would you dump a pail of sand on the hood of your favorite car?
your boat, your choice
-na -NA Anywhere USA
Beaching a boat, care must be given because wave action will cause the bow to move about in sand and over time will damage the bow. Think of it this way. You will be sanding the bow area of hull. There is and I cannot remember the item but there is an item you can add to the bow as a protector
dmax
Jul 29, 2018
1,257
Telstar 28 Buzzards Bay
Best to use a stern anchor ang get close to shore without actually beaching it and then set an anchor from the bow on the beach. Almost as good as beaching it.
Keel Guard
Apr 26, 2015
663
S2 26 Mid On Trailer
Here we are beached as I write this. Our boat has a high freeboard so a ladder is required.We have attachment points on the stern and both sides for this ladder. The gang plank is a work platform that I trimmed the legs on.
Normally the wood plank is not used but we wanted to stay at this shallow site due to 25kt winds today. I added 3 layers of Kevlar to the areas that rub on the sand.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
Good point. But I wouldn't take my favorite car in the ocean either. Maybe my second favorite car, though.
Jun 14, 2010
2,409
A dinghy yes, but I protect the bottom paint and hull as much as possible on my larger boat. That means no beaching.
