Removal of oil filter on Beneteau First 38
Apr 17, 2019
57
Beneteau First 38 Kemah
The oil filter on my Beneteau First 38 is stuck hard, and I am having trouble finding any leverage with any wrench (mainly due to lack of space). Any suggestions? Will the filter unscrew more easily with the engine warm?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
....... Will the filter unscrew more easily with the engine warm?
Definitely would try that. Always warm the engine up before changing the oil and filter. Once you remove the filter with gasket, reinstall a new one and hand tighten and then give it one quarter turn. This allows the filter to fit securely without being too tight. The attached link provides some options untighten.
Likes: BigEasy
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
I had to drive a screw driver through the canister once because I could not get a wrench on thr filter (an old car of mine). Made a heck of a mess, but the screw driver gave me enough grip and leverage to turn it off by hand.
Good luck,
Likes: Bob S
Jan 7, 2014
462
Beneteau 45F5 51551 Port Jefferson
I use a filter wrench like this for years, never had a problem with access. :
Likes: NYSail
Apr 17, 2019
57
I wish I had an answer to your problem. Unfortunately, I am here looking for a solution to the same problem. Guess I'll have to resort to the screwdriver (and clean the resulting mess)...
I’ve had some success with strap wrenches in some spots like that. Might give leverage if you can’t quite get a good enough angle for a standard oil filter wrench.
Mar 6, 2008
1,515
From Autozone.
If the oil filter surface is oily, the rubber strap looses traction. I put pieces of sandpaper between the strap and the filter. Since it is continuously adjustable it can be used for fuel filters as well.
RitSim
Jan 29, 2018
457
Beneteau 411 Branford
If the strap wrenches fail, I've used a screw driver or cold chisel on the metal rim close to the engine. First create a dent in the rim then angle your tool of choice to rotate the filter.
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
I have a filter “wrench” that fits the bottom of the filter with a 3/8 socket wrench fitting in it. Just enough extra leverage to get the job done.
I have had it so long I can’t remember where I got it, but used it to get the oil filter off my lawn tractor engine.
I recall seeing those for the bigger automotive filters as well.
