Compression load calculation
The problem: imagine a right triangle
The vertical leg is 10 ft long point a to b
The horizontal leg to the right is 4ft long point b to c
Imagine a mast with a spreader
The angle at a is 22digrees (b to c)
Angle at b is 90 degrees
A
B———-C
The vertical load at c is 37,500 lbs (down)
What is the compression load c to d ??
Thanks if you can help !!
Nick
A
B———-C
Nick
