New electric windlass
Feb 28, 2018
10
Hunter 336 Ventura California
I have a 1995 Hunter 33.5 that's never had an electric windlass, or any windlass of any kind. I'm going to install one and wonder if any of you have gone through the same install and might have any tips or help of any kind. My anchor locker is not deep so I'm selecting a horizontal version. Any tips?
Thanks, Joe
capta
Jun 4, 2009
5,099
I really like the Lofrans windlasses. The last one lasted some 30 years and was still functioning well, but a couple of the mounting feet had corroded away.
Jan 25, 2011
2,439
S2 11.0A Anacortes, WA
Since your anchor locker is shallow, be prepared to flake as you raise...Think about a vertical mounted over to the side a bit and modifying locker doors. This keeps the deck footprint down. My locker had two doors that opened port/stbd. I made the stbd door part of the deck and mounted a vertical on that door as far aft as possible. This took a lot of glassing and kept the motor below deck. Access to the locker is through the port door. So, the reason for all this diatribe is to make sure you think of numerous possibilities. I can shoot some pics if wanted. Give me an excuse to go to the boat..
Jun 21, 2004
3,220
Beneteau 343 Slidell, LA
Joe,
Around 20 years ago, I had an ‘88 Hunter 33.5. Know your situation regarding the shallow anchor locker. There was a guy, here on SBO, who adapted his locker and fabricated an aluminum mounting plate an anchor roller to accommodate a windlass. Check out the archives, you may find his posts there.
Hunter 37.5 Jacksonville FL
Joe,
Had same issue with my 37.5. Anchor locker not very deep. Installed horizontal windlass and works just fine
Dec 14, 2003
1,450
Joe,
Don't know if this can help but I had the same issue on my 34 and solved it as per the attached. Took some effort and work but all worth it as I'm going on my 13th years. During the 4th year I had some issues with the horizontal Lewmar but they were true to their word and sent me a new one which has been working perfectly since. Good luck with your installation.
10
Defender.com is having their annual sale right now with some good deals. I like the Maxwells
Thanks Mike, but I was looking for how you may have added a windlass and what kind suited your problem best.
Feb 28, 2018
10
Thanks. Loved the videos but none addressed my problem.
Feb 28, 2018
10
Thanks Mark. Some pics would be much appreciated.
Feb 28, 2018
10
Joe,
Thanks BigEasy, I'll check it out.
Feb 28, 2018
10
Joe,
Thanks Claude. This really helps, and your cataloging of the job is excellent!
Feb 11, 2017
35
I ended up installing a vertical windlass with the motor located in the peak of the vberth. I chose this location for 2 reasons - I didn't want to consume a significant part of my anchor locker with braces and mounting plates. The second reason is that most people suffer severe corrosion having the motor in a wet anchor locker
Feb 28, 2018
10
Thanks again Mike, the pic helps. Wish I could see inside the locker though. I don't think my locker is deep enough to accomodate this type of install.
Feb 11, 2017
35
My anchor locker is simply anchors, chain and rode (sorry. No pictures). The windlass motor is in the front of the vberth ( I can't seem to find pictures and the boat is on the hard for the winter, )
