I have a 1985 Capri 22. I would like to remove a set of older Barient 10 winches so I can replace them with a set of new Harken 14 self tailing winches. The Barients don't seem to have circlips or split rings on top to help remove the drum...which needs to happen to access the mounting bolts. The thru deck mounting bolts/nuts are spinning under the deck so can't remove from below. Also, I imagine I'll have to tap new holes for the larger diameter winch base. Anyone been there, done that? Thx!
