Look up the newer Catalina Sport 22 or new Catalina 22 which offered a mast raise system similar to the Hunter system. If any difficulty, send me a private message. Retired Catalina and Hunter dealer.
Where my rudder mounts, I have a piece of 3 inch PVC pipe that is notched to sit over the mount. A couple of straps go to the top to hold it down and in place. At the top of the pipe, I put a V-roller. This is the same as for transport, so all I need to do when I arrive is unstrap the mast. Grab the base of the mast and roll it back on the V-roller. Make sure to get as deep of a V as you can find, otherwise the mast wants to roll off one side or the other.@LeeandRick The worst part of the process is moving the mast from it's trailering position to the raising position (or vice versa). Haven't figured a way to make that easier or safer yet.
Yep, I have a mast support with roller. Between trying not to fall off the deck, step through my plexi windows, or tangle my rigging, carrying half the mast back to the step is still less than comfortable. Guess I just need to "man-up".Where my rudder mounts, I have a piece of 3 inch PVC pipe that is notched to sit over the mount. A couple of straps go to the top to hold it down and in place. At the top of the pipe, I put a V-roller. This is the same as for transport, so all I need to do when I arrive is unstrap the mast. Grab the base of the mast and roll it back on the V-roller. Make sure to get as deep of a V as you can find, otherwise the mast wants to roll off one side or the other.
Have you considered adding some other temporary roller device(s) on the foredeck or cabin roof? Just roll the entire mast to the location. I’m not as “nimble - cat like” these days eitherYep, I have a mast support with roller. Between trying not to fall off the deck, step through my plexi windows, or tangle my rigging, carrying half the mast back to the step is still less than comfortable. Guess I just need to "man-up".
No kidding. Otherwise I can promise that you will drop a pin or a clip in the water never to be seen again. Its bad enough to try and find them in a gravel parking lot.Note this only works if boat is on trailer!
Hunter 216 Owner Modifications and Upgrades
Hunter 216 Owner Modifications and Upgradeshunter.sailboatowners.com
Well more of a need for a substantial anchor point for the winch. However I get your point about dropping stuff. I did a lot of work with my Dad and as he aged he would tend to drop stuff, he would cuss a little and then say “well it is the first day with my new hands and I’m not used to them yet”No kidding. Otherwise I can promise that you will drop a pin or a clip in the water never to be seen again. Its bad enough to try and find them in a gravel parking lot.
That's a nice rig you have! I thought my gin pole and brake winch was easy, and you have to show me a push-button... Love it!Have you considered adding some other temporary roller device(s) on the foredeck or cabin roof? Just roll the entire mast to the location. I’m not as “nimble - cat like” these days either
If you don’t want to muscle the mast up this is solution that I have adopted. Once I have the mast step pinned I stand in the cockpit with one hand on the winch controller and the other to steady the mast. Easy Peasy
I didn’t go with the trailer hitch wiring from the original design. I just used a lawn tractor battery for power source. With one hand on the mast I can feel if it starts to lean one way or another and compensate. The downside is I can’t easily sense if one of the shrouds get hung up on something.That's a nice rig you have! I thought my gin pole and brake winch was easy, and you have to show me a push-button... Love it!
