The beauty of a 2 stroke is that they weigh around half of what a 4 stroke of the same HP weighs. Are you going to sail in a lake, a river or coastal sea waters? Anywhere there might be currents and strong prevailing winds I would recommend the 9.9HP. What is the HP rating for the British Seagull? Your boat could be a little underpowered with the 4HP model and perhaps the 6HP model would be more appropriate to operate in mostly calm waters.. Check your motor mount for weight restrictions. In older models they were rated for HP which it is understood to mean the approximate weight of a 2stroke engine for that horsepower. What type of sailing are you going to be doing? Racing, overnighting or just day sailing? Would you be trailering to other bodies of water like rivers where currents may come into play? Lastly think about maintenance and parts availability for both engines. The 9.9 HP will burn approximately 1GPH + the added 2 stroke oil. Also check the length of the outboard legs as the longer one will work better in a sailboat. There is also the prop; either or both of the engines may not be propped correctly for your boat. Manufacturers use an average size to try an accommodate most boats but I have found that in most instances they are pitched too high for the displacement hulls of a sailboat. I would venture to say that the Sea Gull would be better propped. If you can try them both and see which one works best.I haven't had my busy in the water yet... I have a choice between a 9.9 two stroke and an old British seagull... I think the 9.9 might be too heavy.
dues anyone know if the British seagull will push it good enough? it seems like it should
6 hp Tohatsu long shaft Sailpro is the motor of choice by far here on the forum. Moves you along just fine at hull speed and sips fuel. Yes they do weigh a bit more than a 2 stroke, but not by much. Suggest you do a search here, plenty of posts on the topic....What is the best outboard for a older Catalina 22?
My old boat had one of those. An oldie but a goodie! I didn't keep it long (the boat or the motor) but the darn thing started on the first pull every single time. A good buy for the budget challenged, mechanically advantaged sailor.Looking at a Johnson sailmaster 8, its an older 2 stroke for $300.
Need to keep cost down, I'm in the process of rebuilding this 1977 Catalina 22. Motor just seems to be a good price for starter.My old boat had one of those. An oldie but a goodie! I didn't keep it long (the boat or the motor) but the darn thing started on the first pull every single time. A good buy for the budget challenged, mechanically advantaged sailor.
But the question was "best", so I'll cast another vote for the Tohatsu Sailpro. Ours has been 100% reliable for five years now.
I have a 30 Catalina which I removed the old diesel engine and replaced with a Suzuki 9.9 long shaft on the aft end. With a little more than 1/2 throttle it will push at hull speed. I live on the Gulf and when leaving the harbor to open sea in bound or out I have never had a problem with strong currents. This is not an open water boat that might get into ruff seas, so not worried about 3 to 6 foot seas and prop coming out of the water. I have it on a lift mount. A long shaft is the only way to go.What is the best outboard for a older Catalina 22?
About 60 years ago my family owned a boat with a Seagull outboard. It was noisy and really stinky. Think clouds of obnoxious choking smoke. Needed lots of care to run reliably and was probably horribly polluting with the oil to gas ratio of 1:20 (if my memory is correct).The Johnson Sailmaster would be better than the Seagull if it is in good condition..
That must have something to do with your mount. The shaft on our Tohatsu (which IS offered in extra long, although we don't have it) could easily be four feet long and still never touch the water, even heeled hard to port.Be ware of recommendations for an "extra long shaft" (not an option with Tohatsu, but it is with other makes). There's not enough swing on the motor mount to lift the prop out of the water when in the up position, which can cause two problems - 1) the prop will drag in the water when you're under sail and 2) it can create maintenance issues if you dock your boat for long periods (which I do).
