Does anyone know the torque settings for re-assembling the gearbox coupling on the inboard end of the prop shaft and the propeller nut please? Its for a 3YM on a 2009 Beneteau Oceanis 37, but I guess the engine is more important than the boat.
In summary we require torques for three different nuts:
- The 24mm nut that holds the prop shaft coupling onto the prop shaft
- The 4 M8 bolts that hold the prop shaft coupling onto the gearbox coupling
- The nut that holds the propeller on
