Any good solvents or brush attachments for a dremel to remove adhesive from fiber glass?
Would Re-Mov be compatible with Lexan or acrylic? I need to re-bed some skylights and hatch lenses.The best polyurethane and silicone remover I’ve ever used is Re-mov. It doesn’t dissolve the old sealant, it breaks the adhesive bond between the sealant and the surface. I use a razor or scraper to lift under the edges, a toothbrush, or a terry cloth. It’s so good I bough a case of it and gave it as gifts to my friends!
I haven’t found acetone, denatured alcohol, lacquer thinner, WD40, or 3M Adhesive Remover to be very effective.
Practical sailor recommends Remov or Boatlife Release. I’ve never used the Boatlife product but it got good reviews from PS.
Re-Mov is for silicone. Debond is for polyurethane/polysulfide. I use Debond a good bit. Follow the instructions.The best polyurethane and silicone remover I’ve ever used is Re-mov. It doesn’t dissolve the old sealant, it breaks the adhesive bond between the sealant and the surface. I use a razor or scraper to lift under the edges, a toothbrush, or a terry cloth. It’s so good I bough a case of it and gave it as gifts to my friends!
Do you have a place you purchase from? Is it called MEK?That looks like it might be old butyl rubber sealant. Is it still soft and sticky? I use MEK to remove old butyl and other sealants like 3M 4200. It’s like acetone, but it doesn’t evaporate as quickly.
MEK stands for methyl ethyl ketone. it’s a common solventDo you have a place you purchase from? Is it called MEK?
I’ve just been buying it at Home Depot. When I was there last week I noticed they were selling an MEK substitute. Haven’t tried it yet and I’m not sure why there is a substitute.Do you have a place you purchase from? Is it called MEK?
Substitutes are a weird subject. Notice it does NOT say on the label what it is. You can Google the SED and I recall it is acetone with a little ethyl acetate.I’ve just been buying it at Home Depot. When I was there last week I noticed they were selling an MEK substitute. Haven’t tried it yet and I’m not sure why there is a substitute.
