Those are not made specifically for marine use?They are standard issue 5 pounders. That is what we call them in the USA. I own 2 of them.
I think you will be hard pressed to find aluminium or composite 5lb propane tanks anywhere. If you do, please let us know where.Those are not made specifically for marine use?
They are everywhere......I think you will be hard pressed to find aluminium or composite 5lb propane taks anywhere. If you do, please let us know where.
When looking in the spring, I was only able to find a Worthington 5 lb (4.25) steel propane tank. The smallest aluminum or composite (fiberglass) I could find were 10 lb tanks except for a very tall 6 lb cylindrical one manufactured by several companies.T
the West Marine link provided in an earlier post seems to reinforce your observation. The ONLY 5 pound tank shown is steel and is 4.25 pounds. The composite tanks they list are 11 pounds.When looking in the spring, I was only able to find a Worthington 5 lb (4.25) steel propane tank. The smallest aluminum or composite (fiberglass) I could find were 10 lb tanks except for a very tall 6 lb cylindrical one manufactured by several companies.
They'd be "outside" , like the ones on the home BBQ.Those are not made specifically for marine use?
