Has anyone replaced their Max Prop with a fixed prop? Our 1989 Beneteau First 35s5 has a Max Prop. We bought the boat in June of 2019. We hauled it out for the survey and I checked and photoed the prop. It functions properly, but it is really pitted. I don't know if it was original to the boat 31 years ago, or if was an upgrade. I'm not happy with the performance of this prop. Especially in reverse. It takes a lot of RPM to get it going in reverse and it has nor prop walk, (which I am used to and take advantage of). In close quarters, it is sketchy with this prop. I don't care about the extra speed that it provides. We're not racers. We sail in the SF Bay Area where the currents are strong and I like the extra power when I need it.
So my questions are:
1- Is it likely that the end of the shaft was cut down to accept this prop? I saw installation videos for new Max Props AND THEY CUT THE END OF THE SHAFT OFF!
2- Will I have to source a new prop nut to hold on a new fixed prop?
3- A new fixed prop is in the $ 900. range plus another $ 90. for the bushing from 25mm to 1 1/8". It would take PYI two weeks to refurbish the Max Prop, the cost would be $ 400. to $ 1,000. plus another $ 400. in lay days. Is it worth it to refurbish a 30 year old prop at that rate. No. I just answered my own question.
4- Main question. Is this an easy swap, or should I just work with the old Max Prop?
