Help Identifying...
Sep 23, 2019
44
Beneteau 311 Toronto
Was digging around my boat and found this cluster. Any idea what they may have been attached to?
Where were they? The round one looks a little like the connector Beneteau used for the mast light wiring under our cabin table. Does that wire that seems to come out of the back of the connectors go anywhere?
Sep 23, 2019
44
The whole bundle was packed in with the rest of the rats nest of wiring behind the switch panel. Among the million or so other projects in store I have added tidying this up to my list. Knowing if I can simply pull these out would be a start.
Sep 23, 2019
44
I also found an SSB antenna tuner but no transceiver. Any chance this was once connected to a transceiver?
DougM
Jul 24, 2005
2,242
Beneteau 323 Manistee, MI
The one on the lower left appears to be a Raymarine Seatalk connecter. The seven pin connecter could be for an older chart plotter or gps. As for the other two, good question
Sep 23, 2019
44
Thanks for that. Two down two to go....
Mystery half way solved.
Oct 2, 2013
2
Hunter 206 Hunter 36 Port Royal, SC.
They look to me like Raymarine connectors. one looks like a sea talk connector, one the chart plotter power and one for radar and I don't recognize the last one.
