At the end of the season the SWR on the VHF antenna was a little high according to the built in SWR meter in a Vesper AIS. The SWR was at 3. If I recall correctly an SWR of around 2 is much better. Looking at the connectors the masthead connector is showing some discoloration on the center pin. This might be contributing to the higher SWR.
The current coax is RG 58 (skinny stuff) that is probably original the boat, or about 27 years old. It appears that I have several options,
- Live with the higher SWR
- Replace the coax
- Replace the suspect connector
