Over this winter I am redoing a good portion of my electrical system. I have been extensively reading Mainesails' webpage and I am essentially copying his diagram below, and am going to be ordering a Balmar alt and regulator along with a bunch other stuff from MHT over the winter. Anyways as I was reading his article about voltage sensing I realized when I go to wire the MC-614 voltage sensing lead I'm not quite sure where to put it.
I know it should go on the house positive post, but if the House bank ever has a catastrophic failure and needs to be isolated, then the alt is going to be sensing a bad bank while charging the start battery through the charging bus bar. I was thinking of then putting it on the bus side of the house isolation switch but am worried there would be too much drop through the switch and wires.
What is the best place to put the voltage sensing lead from the voltage regulator?
Do I?
A: leave it on the House Positve terminal (like it's supposed to be) and not worry about the off chance the bank will have a catastrophic failure
B: Put it on the bus side of the emergency disconnect switch, that way it can sense the start battery when in "emergency mode"
C: something else?
Do I?
C: something else?
