310 Keel Bolts
  • Thread starter Deleted member 117556
  • Start date
D
I tightened my keel bolts yesterday for the first time. Was surprised that 2 or 3 of them were snug but not tight and they moved easily. One bolt is so close to the fiberglass side of the bilge that I could not get the socket to seat properly and was not able get leverage to tighten the bolt as much as needed. Any ideas? The bolt is in the bottom left in the attached picture. Tried tapping the socket down with a hammer but was doing that gently and it did not work. Used a torque wrench and standard 1.5 inch socket. Was able to get 7 of the 9 bolts tightened to 80 ft lbs. Will try to get them to 100 eventually but was surprised how hard it was to get to 80. Anyway, would appreciate any ideas about the lower left bolt in the pic....
bob
6,017
Oday 322 East Chicago, IN
Crows foot may fit on the nut that is too close to the bilge wall.
D
Greg,
Thanks for that great suggestion - never heard of that before. Was about to order it but got a longer ratchet extension and used a pipe on the end of the wrench handle and was able to tighten all 9 bolts to 100 ft lbs.:) Going to try again in January when it is out of the water to see if it makes any difference.
Jan 7, 2011
6,017
Greg,
Sound like you are making good progress.
JRT
Feb 14, 2017
2,059
I discovered the cockpit table leg is an ideal "pipe" extention that is realatively easy to get to and use.
Dec 31, 2016
319
Beneteau Oceanis 351 Charlottetown
FYI, they are nuts on yours ,not bolts, and usually indicate a lead keel, hope you are able to get them tightened !
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Looks like it would but very pricey. My torque wrench requires a lot more effort but was only $ 19.95 at Harbor Freight:)
bob
Hey I torque to 150 on a 1/2 inch torque wrench. I top out around 100 on a 3/8. If it requires beyond that or if I had to do it often I would go with a torque multipler.
D
Uhh, are you still talking about keel bolts or something entirely different?
Nov 18, 2010
2,441
Really anything.
But for keel bolts, our bolts are 1" by 8 thread in 316 stainless. Catalina says the minimum torque is 90-100 foot pounds. But the proper torque for the bolts is 299 foot pounds. The concern I had is if the hull could bare the 299 foot pounds on the bolt.
So after looking around on the internet and talking to a few other people I know who have done bolt on keels projects, I set 160 foot pounds as my goal. Like I said, I can get to 150 foot pounds on a 1/2" torque wrench, so that seemed good enough.
